Cable Sag 3
chopin73
Aerospace
Aug 23, 2011
Hi
I'm looking to calculate the sag of a flight control cable under it's own weight (zero tension). The cable is in steel, 5/32" diameter. Does anybody knows the formula to calculate the sag?
Chopin
The equation of a catenary is:
y = a cosh(x/a).
Now how do I determine "a"?
Chopin
i think the post was not about the shape of the curve, but the engineering analysis (force balance) for it ... wiki for a start has something
I looked in two of my mechancial reference books, they have a lot of words, equations and pictures. I can't seem to be able to relay that info into this mode of comunication.
Try looking for an old guy where you work, and ask to see his mechanical reference books.
The equation is:
H = wl^2 / 8d
l = span
H = tension at mid-span
w = load in plf or klf - keep track of units
d= sag
As you can see - the more sag - the less the load and vice versa.
You will NEVER get all the sag out - so make some guess - like 1'' or 2'' or whatever
maybe more like 0.01" or 0.02" ...
w = 0.005 lbs/in
L = 100"
H = 200 lbs
d = 0.005*100^2/(8*200) = 0.03"
which one ?
w is weight (lbf) per in run
L is in of run
H is tension in lbf
(lbf/in)*in^2/lbf = in to me ??
I mis-read. Thought it is was 100 feet. Sorry
These old eyes and Walgreen glasses sometimes just don't work as good as they used to!!
