Dear All,
I have to determine the size of the lighting panel based on the total lighting fixtures connected under each circuit. My calculation is based on the data below:
Total load connected = 3kW
Lighting panel rated voltage = 400V 3Ph+N
Outgoing feeders for lightings = 230V 1Ph+n
Outgoing feeder rating 16A MCB
Continuous current rating of the panel = 3/(1.732*0.4*0.95)
= 4.56A
Adding 20% spare capacity = 4.56*1.2
= 5.472A
I'll have to choose at least 32A MCCB (thermal magnetic type) for the lighting panel incomer in order to be selective with outgoing feeders which are 16A MCBs. However, based on vendor data, incomer MCCB rating must be at least 100A to obtain total discrimination with the load side MCB. If I chooose 100A MCCB as the minimum, my cable size will be also has to be based on the 100A. But I'll be oversizing the cable since the cable will never carry the continous current which is close to 100A due to the small load. If I choose a 32A MCCB I can achieve partial discrimination only.
I'm not sure which way to follow now. Please share your experience on this problem.
= 4.56A
= 5.472A
