  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
Calculate the wind load for the design of a roof beam in the USA
Petras Surna
7
0
0
AU
I am wondering how to calculate the wind load for the design of a roof beam in a house in the USA.
I am aware of ASCE 7. I understand this is the general loading code used throughout the US.
In Australia we have a simplified wind code that is not as intimidating called Wind Load for Housing It's a cut down user-friendly version of the wind code.
Is there a similar code for the US?
Also, a publication or website that steps through how to calculate the wind load for a beginner (me!) would be great.
Thanks in advance.
I think this shall get you start. Note the calculation was based on ASCE7-10. The current ASCE7-16 may contain some changes, but shouldn't be revolutionary. Link
Petras Surna
Ignore retired13’s link. That is a reference to main wind forces that don’t apply to C&C (components and cladding) wind that should apply to a single rafter.
ASCE 7 does offer a standard, and a simple option for C&C wind. I can’t do a search right now but do a search for “simple C&C wind”.
I see, so a ridge beam, roof beam and rafters are "components" in ASCE then. That's good to know.
Searching for "asce simple C&C wind" leads to which is software.
I am after the manual calculations as I want to understand how it's done.
I also found this which says:
"The simplified procedure is for building with a simple diaphragm, roof slope less than 10 degrees"
I definitely need roof slopes greater than this.
If I have to use the "analytical procedure" because there is nothing else that's fine.
Though a worked example for a component would be great :)
petras,
You are a lucky guy, one request, two competing offers with similar content. Anyway, hope these example calculations help to get your feet into the sometimes confusion US wind load provisions. Sorry that I don't know how to pick and chose provisions without offer provisions for main wind force, which forms the base.
Yes I am lucky.
Have to say the going looks tough, just like the Australian code.
So much jargon to take in!!
But the information is there I think.
Here is a complete instruction on "Components and Cladding" wind load provisions and examples. Please make sure your roof beam is covered under this category (explained inside). Link
