ThunderChemE
Student
- Nov 3, 2021
- 1
Currently reading through my textbook and came across a problem asking to find the amount of superheat when saturated steam is expanded across a valve from 500 psig to 15 psig. Correct me if I'm wrong, but when saturated steam is expanded such as this, isn't the enthalpy constant? I used the steam tables and found that decreasing the pressure of the saturated steam from 500 psig (giving a temperature of 470 F and an enthalpy of 1204.9 Btu/lb) to 15 psig would just produce superheated steam at 15 psig and about 331.7 degrees Fahrenheit. I guess the question is confusing me a bit because until now I believed that the "amount of superheat" had to do with a change in enthalpy when going from saturated to superheated conditions. Any help would be greatly appreciated.
