MohdYaseen2010
- Nov 26, 2007
- 101
With respect to calculating of MAWP for ASME VIII vessel after specifying it’s nominal thickness, I found two concepts;
One stating that the MAWP shall be calculated using nominal thickness & another specifying Corrodd nominal thickness (nominal thickness - corrosion allowance), I think is the latter is right? What do you think.
Mohd Yaseen
Mohd Yaseen
