I'm considering using a self bailer on a boat to draw out water from a well in the hull (Self bailer image linked). It swings down into the waterflow. Waterflow can be anywhere from 3 to 20kn. When the well is empty the bailer will be 350mm below the waterline. For it to be successful it will need to work reasonably efficiently at that depth. Reasonable efficiency is somewhere close to an average of 1/2 litre per second ideal would be 1 lps.
I can't find manufacturer specifications.I can find the online information for pipes but these are very different (I assume different) and I can't find any leads. I'm not sure where to start, any leads would be much appreciated,
Dave
Dave
