  • Congratulations Danlap on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Calculation of Residual strength of synthetic hawser rope 1
jayakumaran
Marine/Ocean
Nov 27, 2024
18
I have calculated the hawser mooring rope’s residual strength (life prediction) and need confirmation on its accuracy. Please review my attached PDF. The OCIMF formula R=S−(S−A)(N/e^A(S−L))^B gave unrealistic results due to a very large exponent, so I used an alternative formula and took five example loads and cycles for the calculation in the pdf.
  • Residual_Strength_Calculation (1).pdf
I recommend comparing your calculation results to known/trusted benchmarks. I'd be surprised if anyone here is going to check your calculations.
If I haven't misunderstood - Does it seem likely that in step 2 increasing load gives more cycles to failure? Not being a rope expert or anything...
That’s a great question. The number of cycles should actually decrease as the load increases. I followed the formula, but it seems to have led me in the wrong direction. I applied three formulas—Miner’s Rule, the cumulative damage hypothesis, and the S-N curve formula—but the specific calculation for the number of cycles to failure is not a standard one and was generated by ChatGPT.
If you have any alternative suggestions, I’d appreciate your insights. This predictive calculation is critical to ensuring the safety of the mooring line when the tanker is secured to the buoy.
Thanks for your valuable reply sir.
I understand, AI can be a bit unpredictable sometimes. Thank you for your patience LittleInch and GregLocock. I’ll ensure I provide correct information moving forward.
