Camlock Adaptor Material Selection for CS Pipe Connection 1
az5333
CA
Hi fellow members. I am specifying a camlock Type-A adaptor threaded to a CS pipe nipple for firewater application. The adaptor is there for the vac truck to connect to whenever line draining is required. The camlock Type-A adaptor is only available in brass, aluminum or SS material. My question is, which of these is a better material to recommend to the vendor knowing that there will be different materials connected together? Appreciate input from your experiences on this. Thanks for the help.
I would go for brass myself to avoid any issue with galvanic corrosion and because it looks nice when polished.
Hi LittleInch - thank you very much for your quick feedback. You are surely a very active and knowledgeable member of this group and I follow your responses on other posts very keenly. Thanks again.
