Can a dry ai screw compressor be used for compressing nitrogen?
mechanicaljw
80
Hi All,
I have searched the forum to see if i would get an answer to my question to no avail. I am therefore posting the question here:
Would it be possible to use a dry screw compressor that compresses air from atmospheric to 3.5 bar(a) for compressing nitrogen and get the same compression without making any modification to the screw rotors or the compressor design?
The reason is because the process needs pure nitrogen.
Thank you in advance for your response.
Jimmmy.
