I am trying to create a simple indentation simulation but I keep getting this error below.
1
Abaqus Learning Edition 2024 Date 31-Jan-2025 Time 14:34:51
PROCESSING PART, INSTANCE, AND ASSEMBLY INFORMATION
***ERROR: in keyword *RIGIDBODY, file "Job-1.inp", line 1660: Unknown assembly
set B_SET-1
***NOTE: DUE TO AN INPUT ERROR THE ANALYSIS PRE-PROCESSOR HAS BEEN UNABLE TO
INTERPRET SOME DATA. SUBSEQUENT ERRORS MAY BE CAUSED BY THIS OMISSION
END PROCESSING PART, INSTANCE, AND ASSEMBLY INFORMATION
OPTIONS BEING PROCESSED
*Heading
*Element, type=C3D8R
*Elset, elset="ASSEMBLY_Test plate-1_SET-1"
*Elset, elset=ASSEMBLY_SET-3
*Elset, elset=ASSEMBLY__SLAVE_S3
*material, name=MATERIAL-1
*elastic
*plastic
*solidsection, elset="ASSEMBLY_Test plate-1_SET-1", material=MATERIAL-1
*rigidbody, refnode=ASSEMBLY__PICKEDSET12, elset=ASSEMBLY_B_SET-1
***ERROR: ELEMENT SET ASSEMBLY_B_SET-1 HAS NOT BEEN DEFINED
*contactpair, interaction=INTPROP-1, type=SURFACETOSURFACE
*surface, type=ELEMENT, name=ASSEMBLY_SLAVE
***ERROR: THE MAIN SURFACE ASSEMBLY_MASTER DOES NOT EXIST.
*surfaceinteraction, name=INTPROP-1
*surfacebehavior, pressure-overclosure=HARD
*friction
*boundary
*boundary
*boundary, amplitude=AMP-1
*boundary
*boundary
***ERROR: THE ELEMENT SET ASSEMBLY_B_SET-1 (USED TO DEFINE A RIGID BODY) WAS
NOT FOUND.
END OF USER INPUT PROCESSING
JOB TIME SUMMARY
USER TIME (SEC) = 0.10
SYSTEM TIME (SEC) = 0.0
TOTAL CPU TIME (SEC) = 0.10
WALLCLOCK TIME (SEC) = 0
1
set B_SET-1
*Heading
*elastic
*plastic
*friction
*boundary
*boundary
*boundary
*boundary
NOT FOUND.
JOB TIME SUMMARY
