  • Congratulations Danlap on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Can bend beam Rebars 90 deg vertically inside lift wall instead of straight towards wall?
LewisLiew
20
I am inspector of work.
Would like to know whether bottom or top rebars for 1st floor beam CIS B 4T32 to bend 90 deg to top/bottom at approximately 300mm (Drawing shown straight 1200mm inside lift wall & 800mm each). I am asking because contractor will put foam at lift wall 300mm so later can cast beam.
