escapizm
Marine/Ocean
- May 14, 2013
- 40
Q) I have an existing rigging assembly with a hook rated to 25Te WLL, the static load is 22Te, applying a DAF of 1.3 gives 28.6Te. is the hook ok?
Tks
Tks
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Your latter comment surprises me. A load being lifted is not static by definition. Yet as far as I'm aware in basic lifting a dynamic factor is not normally applied to your load.Craig_H said:In my past work in the specialized lifting field,... In short, your static load only matters if the situation is... static! Otherwise, I'd be designing to the dynamic load, and taking care to ensure that the lifting equipment has undergone recent NDT to ensure that other dynamic loading hasn't caused fatigue damage.
DNVGL said:16.5.2.6 The shackle dynamic load (considering all relevant factors in [16.3.4.1] and including DAF) shall
not be greater than the least of the following:
a) WLL stated on the certificate x DAF
b) Shackle MBL/3.0
c) Documented proof load value for the shackle (see [16.12.3.1] for proof load test documentation
requirements).
The above requirements are applicable subject to the following conditions:
— The lift is an engineered lift taking in to account all the applicable factors and requirements of this
standard.
— The MBL is derived using the correct factor of safety (manufacturers have different factors of safety).
This is particularly important if a shackle is changed out during the course of a project.
Guidance note:
Where local or national regulations are different to those contained in this standard, then those regulations shall be considered
governing if this provides a higher level of safety or serviceability than this standard.
Where other requirements are different to those contained in this standard (e.g. client or lifting contractor), then these may be used
providing they give a higher level of safety or serviceability than this standard.
---e-n-d---of---g-u-i-d-a-n-c-e---n-o-t-e---
LOLER ACOP said:Overload
282 A load greater than the SWL or rated capacity should not be lifted except
where, for the purposes of thorough examination or testing, the competent
person requires it.
