can i apply continuous 9Vdc power supply to 24Vdc DIOD OR-ing Unit to power up 9Vdc media converter
suresh448online
3
I have a diode ORing unit, model 'P-OR-24-10', which operates at 24Vdc. I am applying two continuous inputs (primary and redundant) of 9Vdc each to this OR-ing module and supplying its output to a TP-media converter (model: MC210CS, with an input supply of 9Vdc). Will this configuration work reliably over a long period? However, the component used in Diode OR-ing unit is 40CPQ045 Schottky rectifier, which has 'Max. Forward Voltage Drop is 0.56Vdc only.
wrong forum for your question - please re-post in the correct forum and delete this post
