In our plant there is an anchor support that we would like to convert it to a guide. Support is made of a vertical HSS254x254x8 welded to a base plate which itself is bolted to concrete floor. A 6" CS standard horizontal pipe going through this HSS (thru 2 holes) and welded all around to it by a 5 mm fillet weld. I suggested that we cut the fillet weld (by grinding or cutting) and remove the HSS and change it to a guide support. However concerns raised that fillet weld removal can take some of the wall thickness and therefore would be a source of stress concentration. I would like to know how much this concern is valid and if so how we can address this concern. Pipe carries water at 800kPa(g)/ 0-35 deg C.
Finally due to other limitations cutting and replacing that section of pipe can be very difficult and expensive task.
Thank you in advance for your inputs.
