Can't Find a Wrench 3
chris456s
SG
I need to find an open end or adjustable wrench for an M100 heavy hex nut. the dim across flats is 145mm to 150mm. I can't find a wrench with 150mm jaw width or an adjustable that can open that wide. Does anyone know of a website or supplier with such a wrench? These are a standard size nut but How do people turn these nuts if wrenches this size are not available?
I'd be lying if I said I've never used a pipe wrench in situations where I just didn't have a large enough "real" wrench.
The best part of using a pipe wrench is that it doesn't really matter if the corners get rounded off.
If you have some time you might look at "Super Bolt" multi jack screw style fasteners.
I made my own version awhile back and it work really well especially since we were assembling and dis-assembling a weld fixture for about 12 units.
Burn a wrench out of 1045 plate if it is just for occasional use. You can also contract a bolting service to remove/replace on-site, or rent a hydraulic torque wrench.
What is the "turning" you need to apply to this nut / these nuts ?
Loosen, snug tight, some desired torque ?
What is the clearance available for the "wrench" and the turning effort ?
dvd: You have to be careful with that; many locations would hand you your a** for using a 'homemade tool'.
Viper - agreed. One can always load test. There are also a great many 'store bought' wrenches that are not load rated. I can understand your comment more in the context of lifting and hoisting with fabricated lifting components. If it is going to create a safety concern make sure it is going to be safe.
I'd recommend contacting a few tool companies directly that do their own forging. Obscure tools in many cases aren't advertised due to rarity of their sale. I wouldn't recommend a pipe wrench, more common in that size and style but proper for removing hex fasteners would be a large F wrench like the good ol Ridgid spud series. As mentioned above, in many cases a tech will simply burn his own out of reasonably thick plate.
Hey, what'w wrong with the tried and true hammer and chisel method? No rounded corners to stop you.
