zero1238
- Oct 6, 2017
- 74
I have a client with a house raised on 18"x18" concrete columns due to being located within a flood zone. They are looking to attach an AC condenser platform to the sides of two columns, which will weigh approximately 2,000 lbs. As I'm not that familiar with these kinds of designs, how would you calculate the shear and pullout strength requirements for the concrete anchors if the platform was cantilevered 5' out from the column with that 2,000 lbs load right in the middle? Any guidance is very much appreciated. Thank you.
