I am designing an open carport structure using a cantilevered column system with multiple columns in an area with very high snow loads (almost 100 PSF roof snow load). Because of those very high snow loads, I am finding it a little tricky getting under the 15% axial capacity requirement with economical column sizes, although I can get kind of close. The commentary mentions the requirement being put into the code after collapse of some apartment buildings utilizing this system due to lack of redundancy. For the structure I'm designing, which has a lower loss of life risk than an apartment building, 15% seems a little strict/conservative. Does anyone else agree or is 15% a hard line not to cross? I am using a k value of 2.1 for the column design.
