mike deiters
- Aug 26, 2022
- 2
Hello everyone, new here and have a question for the SMEs on this board
first I am a PE in GA in Civil Engrg. Recently ,I inspected a homeowners driveway after a tree removal company brought a 68,000 lb truck crane in to remove a 44" white oak that fell on his house as well as a 50,000 lb grapple truck to haul the logs.
the work caused some settlement / lateral movement of the compacted fill subgrade as evidenced by displacement of granite cobble curbing on the driveway edges
granite curbing on each side of the driveway was displaced 1-2" from the driveway edge. as built's show a 1/2" construction joint between granite cobble and concrete and the new gap is obviously new and due to the excess loading
the load also caused some cracking in a few places but primary issue is the long crack / separation between the curbing and concrete drive which will lead to water infiltration, freeze thaw, undermining the aggregate base over time.
so after that background, I would like to know the approximate capacity of the 4" slab / 6" aggregate. Slab is reinforced 2' o.c. each way.
assume soil bearing capacity 2,000 psf.
I have read that these common driveway slabs are built for 8-10K lbs which is a passenger car, obviously not a large piece of const equipment.
Anyway I need a definitive reference to cite, I dont want to go thru a long structural calculation to prove the slab was not designed for these types of loads, I am looking for some references.
thanks guys
thanks guys
