Carbon Brushes Replacement Standard
G_Ahmed
4
I wanted to know regarding the replacement of carbon brushes. What does the standard says, when should we replace our carbon brushes on what length?
There is no "Standard" related to carbon brush replacement.
John
The brush should have a "wear line" - either a milled groove, or a painted line - about 1/4 of the "new" length from the top where the leads connect. How long it takes you to wear the brush down to that point depends on a lot of little things: how much current for how long, how much moisture in the air, what temperature at the brush running surface, whether the surface is a commutator or a collector or a shaft, what the brush material is, how "true" the running surface is, what speed you're running, how much contamination is in the immediate vicinity, etc.
First suggestion - read the operation and maintenance manual that came with the machine. Second suggestion - go talk to your local brush rep (for the brushes you're using). Third suggestion - go talk to the brush rep (that you want to switch to).
Converting energy to motion for more than half a century
