Mech5656
- Aug 2, 2014
- 127
We have a split case pump here with max running temp of 240F and discharge pressure of 1500psi. The case leaked from the center and the stud in that area broke when it was running. Attached is picture of what we found. The gasket is gone in the center area while it was running. Have you see something like this? What can cause this? Can you recommend solutions so this doesn’t happen again?
