Mechville
- Aug 9, 2021
- 7
We have an old 8" cast iron gas main system that we are replacing with PE piping, and the plan is to tee off from the existing cast iron pipe and then run HDPE parallel to the existing cast iron line. What's the best way to tee off of cast iron pipe? I typically work with steel piping where we tee off by welding on a bottom out fitting and hot tap through the existing pipe wall.
I know you can use couplings to switch from cast iron to PE pipe, but that's inline and not a tee. If I can purge the existing line, I suppose the easiest thing would be to remove a section of the cast iron pipe, replace it with a coupling to PE and then a PE elbow to our new PE line, and cap the other side of the to-be-abandoned cast iron piping. But if purging isn't an option due to line downtime and lack of valves, what are alternative options?
