Dear all Steel Experts,
If a contractor ordered and received! Steel Category 2 instead of Category 3 for a steel plate girder. What material tests would you ask the contractor to support that category is still good enough to be used in the girders if the yielding and tensile strength met your design specs... Charpy test results? Chemical components? Any other ideas?
