Here's my issue:
Let's say I have a long surface strip that I split into multiple, shorter surface strips. Then I make a boundary on two of the edges of each of the surfaces, make a line connecting those two edges, and make a sweep using the line and two edges. Lots of things going on, right? Later on, I need to swap out the original long surface strip with another surface...I do that, and hit update on everything else. That "update diagnosis" window keeps popping up for each individual element that needs updating, and man is it annoying. Is there a preference or some way to make Catia be smarter and do all those updates itself? The "update diagnosis" window appears whether or not I have updates set to automatic or manual (preferences->legacy preferences->infrastructure->3d shape infrastructure->general tab->update).
