Catia create points using Excel data
NaWin55
IN
Hello
i am trying to create points using excel X Y Z data
below is the code i have written in VBA, How can i write it without using while or if conditions
Dim opartDoc As Document
Set opartDoc = CATIA.Documents.Add("Part")
Dim oprt As Part
Set oprt = opartDoc.Part
Dim hybshpfact As HybridShapeFactory
Set hybshpfact = oprt.HybridShapeFactory
Dim hybs As HybridBodies
Set hybs = oprt.HybridBodies
Dim hyb1 As HybridBody
Set hyb1 = hybs.Add
Dim opoint As HybridShapePointCoord
On Error Resume Next
Dim oexcel As Object
Set oexcel = GetObject(, "Excel.Application")
If oexcel Is Nothing Then
Set oexcel = CreateObject("Excel.Application")
Err.Clear
oexcel.Visible = True
End If
Dim wrkbk As Workbook
Set wrkbk = oexcel.ActiveWorkbook
Dim osheet As Worksheet
Set osheet = wrkbk.Worksheets.Item(1)
Dim rowsnum As Integer
rowsnum = osheet.UsedRange.Rows.Count
Dim colnum As Integer
colnum = osheet.UsedRange.Columns.Count
Dim x As Double
Dim y As Double
Dim z As Double
Dim i, j As Integer
For j = 1 To colnum
While (j = 1)
For i = 2 To rowsnum
x = osheet.Cells(i, j).Value
y = osheet.Cells(i, j + 1).Value
z = osheet.Cells(i, j + 2).Value
Set opoint = hybshpfact.AddNewPointCoord(x, y, z)
hyb1.AppendHybridShape opoint
oprt.UpdateObject opoint
Next
j = j + 1
Wend
Next
oprt.Update
Excel Data
You dealed with so many codes , CAA and other stuff.Are you sure you can't solve this one ?
i tried other ways without conditions but not getting correct result
i just want to stop column count after all rows counted so that loop wont start from 2nd column again
for that i used if condition
just want to know how to do without CONDITIONS
why do you need "j" and to count columns ?
i am using nested loop to get each row and loop thru column and go to next row and loop thru column until the last row and stop
this is why i am using "j"
to stop the loop i am using condition (once the last row comes stop the loop)
but how to do it without condition
To remove "IF" : assume that excel it's allready opened or create one .
To remove "while" , i presume that columns will always be X , Y, Z ?
Dim i As Integer
x = osheet.Cells(i, 1).Value
y = osheet.Cells(i, 2).Value
z = osheet.Cells(i, 3).Value
Next i
Or i'm missing something ?
