Hi everyone hopefully soneone can correct my code to find number of count of specified text in catia drafting and then replace exact matches only with what i want. Current condition is when i try to replace 1-1 with lets say 2-1, it also replaces the 201-1 with 202-1 since it also has a 1-1 in it.
Dim a As String
Dim b As String
Dim c As String
Dim drawingDocument1 As DrawingDocument
Dim selection1 As Selection
Private Sub CommandButton1_Click()
' Get value from TextBox1
a = TextBox1.Value
' Set up CATIA objects
Set drawingDocument1 = CATIA.ActiveDocument
Set selection1 = drawingDocument1.Selection
' Perform search operation
Dim totalCount As Integer
totalCount = 0
' Loop through all drawing texts and count occurrences of the word
For i = 1 To selection1.Count
Dim textItem As DrawingText
Set textItem = selection1.Item(i).Value
' Check if the text contains the search word using a regular expression
Dim regex As Object
Set regex = CreateObject("VBScript.RegExp")
regex.Global = True
regex.IgnoreCase = True
regex.pattern = "\b" & a & "\b"
Dim matches As Object
Set matches = regex.Execute(textItem.Text)
totalCount = totalCount + matches.Count
Next i
' Update TextBox3 with the count of matching words
TextBox3.Text = CStr(totalCount)
End Sub
Private Sub CommandButton2_Click()
' Get values from TextBoxes
Dim a As String
Dim b As String
a = TextBox1.Value
b = TextBox2.Value
Dim drawingDocument1 As Document
' Set up regular expression for word boundary matching
Dim regex As Object
regex.Global = True
' Loop through the found items and perform replacements
For i = selection1.Count To 1 Step -1
' Check if the search term is a standalone word using the regular expression
If regex.Test(textItem.Text) Then
' Perform replacement
textItem.Text = Replace(textItem.Text, a, b, , , vbTextCompare)
End If
Next i
End Sub
Dim a As String
Dim b As String
Dim c As String
a = TextBox1.Value
totalCount = 0
Dim regex As Object
regex.Global = True
Next i
End Sub
Dim a As String
Dim b As String
a = TextBox1.Value
b = TextBox2.Value
Dim regex As Object
regex.Global = True
End If
Next i
End Sub
