Catia GSD 1
CAD2015
Computer
Jan 21, 2006
1,932
I do not have much experience with GSD...……
How could I cut the number 4 inside (using the three white lines)?
What operation should I use for that?
Thanks!
CAD 2015
From the picture is seems the 3 whites lines might be in a sketch.
If this is the case and only those 3 lines are in the sketch, then you can CUT the surface with the sketch and select the inside/ outside to get the proper side as the result of the cut.
Eric N.
Thanks, Itsmyjob
No, it is not a sketch, but your guess is useful…..
So, what would you suggest in this case?
P.S. By the way.....how to cut with the sketch? What tools should be used for that? Again, I do not much about GSD....
CAD 2015
the actual name of the function is SPLIT not CUT
the 3 lines are a JOIN if not a sketch or at least they are one element in the spec tree.
SPLIT the surface with that element
if that element is more than the 3 line then EXTRACT the 3 lines (point propagation), then SPLIT.
seeing the spec tree usually help...
Eric N.
many video on SPLIT GSD function
Eric N.
