CATIA - IMAGINE AND SHAPE - Convert Surface
m4the0
6
PL
Hello, i would like to know if there is any method to convert standard surface (for example surface made with extrude tool) to subdivided surface that can be manipulated with IMA tools ?
I need to merge "perfect" cylinder sufrace with exact diameter dimension of 100mm with some IMA surface. It is hard to make IMA surface with specific dimension.
