Hi
Could someone point me please what is wrong with catia libaries , will explain a little more the problem i got below .
So i have couple of CATIA versions installed on my machine : V5 ,3DX . I noticed that either in integrated V5 VBA or when using VS for automation if i have both 3dx and v5 opened : reference libraries for ex in V5 gets messy .
Example : i have both versions now opened and i want to run a vba code in v5 and get an error . If i close 3dx (sometimes works - sometimes not only after a machine restart) the vba code works. So i tried to see what is happening - i noticed the code i am using i need drafting library and when i checked it in references it is no more CATIA V5 DraftingInterfaces Object Library but CATIA Drafting2Dld...something which i assume is the 3dx one somehow replaced if i have 3dx opened .
I tried to dig out the problem and found the /regserver stuff which i did for v5 (not in admine mode true ) , but i am not sure if this is the answer.
Please if someone faced this problem and know a resolution will be very much appreciated !
Thank you !
Thank you !
