CATIA Macro apply materials and rename parts
elmundo777
Automotive
BY
Hi all. I have two questions.
First question: there is a macro that renames the product structure in a loop. But if the parts were copied, then the names are duplicated with each step of the loop. Can be seen in the attached picture. How to avoid it?
Code:
For Each Item In myPrd.Products 'Documents
            Nber_Item = myPrd.UserRefProperties.Count
            '''' ' MessageBox.Show(Nber_Item)
            name = myPrd.Products.Item(Item).PartNumber
            '''''MessageBox.Show(name)
            iteration = myPrd.Products.Item(Item).ReferenceProduct.UserRefProperties.Item(1).ValueAsString
            '' 'MessageBox.Show(iteration)
            Status = myPrd.Products.Item(Item).ReferenceProduct.UserRefProperties.Item(3).ValueAsString
            WC_number = myPrd.Products.Item(Item).ReferenceProduct.UserRefProperties.Item(5).ValueAsString
            revision = myPrd.Products.Item(Item).ReferenceProduct.UserRefProperties.Item(7).ValueAsString
            ' MessageBox.Show(myPrd.Products.Item(Item).Name)
            If (CheckBox_STATUS.Checked = True) Then
                rename = WC_number & "_" & revision & "_" & iteration & "_" & Status & "_" & name
            Else
                rename = WC_number & "_" & revision & "_" & iteration & "_" & name
            End If
            ' renaming of the part
            myPrd.Products.Item(Item).PartNumber = rename
            myPrd.Products.Item(Item).Name = rename
        Next
The second question: how to assign a material to each body in a part in a cycle?
