.Catia Surface Edge Fillet
JSVKAN
20
0
0
Hi
I am trying to use Surface Edge Fillet in my coding. I have a trimmed two intersecting surfaces and need to use "Surface edge fillet" on intersecting edge. I tried recording and ran same macro but it does not work. In recorded macro that edge fillet is not selecting support automatically.
Code should select intersecting edge automatically and do filleting. Could you please help me how to do surface edge fillet between two intersecting surfaces?
Sub CATMain()
Dim partDocument1 As PartDocument
Set partDocument1 = CATIA.ActiveDocument
Dim part1 As Part
Set part1 = partDocument1.Part
Dim shapeFactory1 As ShapeFactory
Set shapeFactory1 = part1.ShapeFactory
Dim constRadEdgeFillet1 As ConstRadEdgeFillet
Set constRadEdgeFillet1 = shapeFactory1.AddNewSurfaceEdgeFilletWithConstantRadius(Nothing, catTangencyFilletEdgePropagation, 5#)
constRadEdgeFillet1.FilletBoundaryRelimitation = -2
Dim hybridBodies1 As HybridBodies
Set hybridBodies1 = part1.HybridBodies
Dim hybridBody1 As HybridBody
Set hybridBody1 = hybridBodies1.Item("a")
Dim hybridShapes1 As HybridShapes
Set hybridShapes1 = hybridBody1.HybridShapes
Dim hybridShapeTrim1 As HybridShapeTrim
Set hybridShapeTrim1 = hybridShapes1.Item("Trim.1")
Dim reference1 As Reference
Set reference1 = part1.CreateReferenceFromBRepName("TgtIntersEdge:(GeneratedEdges;MfIE_R20GA;TgtPropagationFillet;FirstOperands:(GSMTrim.1);SecondOperands:();InitEdges:(REdge:(Edge:(Face:(Brp:(GSMExtrude.1;0:(Brp:(Sketch.2;14)));None:();Cf11:());Face:(Brp:(GSMFill.1);None:();Cf11:());None:(Limits1:();Limits2:());Cf11:());WithTemporaryBody;WithoutBuildError;WithSelectingFeatureSupport;MFBRepVersion_CXR15)))", hybridShapeTrim1)
constRadEdgeFillet1.AddObjectToFillet reference1
constRadEdgeFillet1.EdgePropagation = catTangencyFilletEdgePropagation
constRadEdgeFillet1.FilletBoundaryRelimitation = catConnectFilletBoundaryRelimitation
constRadEdgeFillet1.FilletTrimSupport = catTrimFilletSupport
part1.Update
End Sub
Thanks.
Hi ,assuming that you have an edge like this
, script would be different ( here you need the help of an expert) . If you need edges only on X,Y,Z then you can use the script posted by ferdo and itsmyjob :
Sub CATMain()
' get myPart
Dim myPart ''As Part
Set myPart = CATIA.ActiveDocument.Part
' get selection object
Dim selection1 ''As Selection
Set selection1 = CATIA.ActiveDocument.Selection
' search all edge in part
selection1.Search ("Topology.CGMEdge,in")
' loop all selection
For i = 1 To selection1.Count
' get edge from selection
Dim myEdge As Edge
Set myEdge = selection1.Item(i).Value
' get edge Dir
Dim dir(2)
myEdge.GetDirection dir
' for info
Debug.Print dir(0) & " / " & dir(1) & " / " & dir(2)
Dim MyFillet As ConstRadEdgeFillet
' checking if dir is along Y and also that edge is not from sketch
If Abs(dir(1)) = 1 And InStr(1, TypeName(myEdge), "monodim", vbTextCompare) = 0 Then
MsgBox myEdge.Name
Set MyFillet = myPart.ShapeFactory.AddNewSurfaceEdgeFilletWithConstantRadius(myEdge, 1, 3) - ' replacing here the type of fillet
End If
Next
myPart.Update
End Sub
In my opinion (beginner level one ) you should search them by name if it's first case.
Select all edges from assembled trimmed surface, then store all edges in a collection1.
Select all faces of trimmed surface, and store faces in collection2
check each edge with each surface, not so many will have a distance = 0... find another relation that will filter more the collection1 so you have only one edge.
use that edge for Reference for the fillet instead of trying to use BREP name.
just thinking out load.... I let you proceed...
Eric N.
As shown in the image, I have to remove or do not want to consider edges inside the cavity, cavity boundary and outer surface boundary. I have to use surface edge fillet only on the small closed edges mentioned in the image. I am new for CAT VBA and do not have much experience on coding. So if you have any sample code for surface edge fillet, Please post.
Thanks.
As for now it's not programming, but engineering question. And it goes like this: how would you define edges that needs to be filleted without actually looking at the part (i.e. with math, not with tour eyes)?
