Sid Pattisapu
- Aug 7, 2023
- 1
Hello, I am fairly new to CATIA v5 Macros. I'm fairly new to Macros in CATIA v5. I'm having trouble Isolating a sketch in CATIA using Macros. Similarly with changing the sketch support. Is there a quick way that I can do both of them?
This is my code
Sub CATMain()
Dim partDocument1 As Document
Set partDocument1 = CATIA.ActiveDocument
Dim part1 As Part
Set part1 = partDocument1.Part
'-----------------------------Extraction and sketch operation--------------------
Dim sel As Selection
Set sel = partDocument1.Selection
sel.clear
sel.search("..Name='Step.3',All")
Dim extract1 As HybridShapeExtract
Set extract1 = sel.item(1).value
part1.UpdateObject extract1
sel.clear
sel.search("..Name='Step.4',All")
Dim plane1 as AnyObject
Set plane1 = sel.item(1).value
part1.UpdateObject plane1
sel.clear
Dim hybridShapeFactory1 As Factory
Set hybridShapeFactory1 = part1.HybridShapeFactory
Dim origin As HybridShapePointOnCurve
Set origin = hybridShapeFactory1.AddNewPointOnCurveFromPercent(extract1, 0, False)
origin.Name = "Point.origin"
Dim hybridBodies1 As HybridBodies
Set hybridBodies1 = part1.HybridBodies
Dim hybridBody1 As HybridBody
Set hybridBody1 = hybridBodies1.Add()
hybridBody1.Name = "Point"
hybridBody1.AppendHybridShape origin
part1.Updateobject origin
Dim endpt As HybridShapePointOnCurve
Set endpt = hybridShapeFactory1.AddNewPointOnCurveFromPercent(extract1, 1, False)
endpt.Name = "Point.end"
hybridBody1.AppendHybridShape endpt
part1.Updateobject endpt
Dim hax As HybridShapeLinePtPt
Dim Ref1,Ref2 As AnyObject
'Set Ref1 = part1.CreateReferenceFromObject(origin)
'Set Ref2 = part1.CreateReferenceFromObject(endpt)
Set hax = hybridShapeFactory1.AddNewLinePtPt(origin,endpt)
hax.Name = "haxis direction"
hybridBody1.AppendHybridShape hax
part1.Updateobject hax
Dim haxis(2)
hax.GetDirection haxis
sel.Search("..Name='Step.5',All")
Dim sketch1 As Sketch
Set sketch1 = sel.item(1).value
Dim Coord(2)
origin.GetCoordinates Coord
Dim absdata(8)
sketch1.GetAbsoluteAxisData absdata
absdata(0) = Coord(0)
absdata(1) = Coord(1)
absdata(2) = Coord(2)
absdata(3) = haxis(0)
absdata(4) = haxis(1)
absdata(5) = haxis(2)
sketch1.SetAbsoluteAxisData(absdata)
sel.clear
sel.Add sketch1
CATIA.StartCommand "Isolate"
part1.UpdateObject sketch1
sel.clear
'part1.IsolateObject sketch1
'part1.update
End Sub
The SetAbosulteAxisData command sets the sketch where i want it to be but doesnt update the geometric support. Also, the Isolate command doesnt seem to be doing anything
This is my code
Sub CATMain()
Dim part1 As Part
sel.clear
sel.clear
sel.clear
Dim haxis(2)
Dim Coord(2)
Dim absdata(8)
sel.clear
sel.Add sketch1
sel.clear
'part1.update
End Sub
