CATIA V5 Macro - changing orientation of axis system
vangilme
Hi all. First time posting. I wanted to create a macro that would allow the user to choose a geometrical set containing points and an axis system, and the macro would generate a series of axis systems with their origins at the points in the geometrical set, and aligned with the axis system chosen. I can get the axes to the right location, but trying to align them has been a nightmare.
Code:
Sub CopyAxisToPoints()
    Dim fil(0)
    Dim oPoint As Point
    Dim newAxisSystem As AxisSystem
    Dim oldAxisSystem As AxisSystem
    ' Get active document
    Set Document = CATIA.ActiveDocument
    Set Part = Document.Part
    Set oSelection = Document.Selection
    ' Prompt user to select the geometrical set
    oSelection.Clear
    fil(0) = "HybridBody"
    oSelection.SelectElement2 fil, "Select a geometrical set", False
    Set geometricalSet = oSelection.Item(1).Value
    ' Prompt user to select the axis system
    oSelection.Clear
    fil(0) = "AxisSystem"
    oSelection.SelectElement2 fil, "Select an axis system", False
    Set oldAxisSystem = oSelection.Item(1).Value
'    Dim vXValues(2), vZValues(2)
'    vXValues(0) = 1
'    vXValues(1) = 0
'    vXValues(2) = 0
'    vZValues(0) = 0
'    vZValues(1) = 0
'    vZValues(2) = 1
'    Dim vXValues(2) As Double, vZValues(2) As Double
'    oldAxisSystem.GetXAxis vXValues
'    oldAxisSystem.GetZAxis vZValues
    Dim vXValues As Reference, vZValues As Reference
    Set vXValues = oldAxisSystem.XAxisDirection
    Set vZValues = oldAxisSystem.ZAxisDirection
    ' Loop through all points in the geometrical set
    For i = 1 To geometricalSet.HybridShapes.Count
        If TypeOf geometricalSet.HybridShapes.Item(i) Is Point Then
            Set oPoint = geometricalSet.HybridShapes.Item(i)
            ' Create a new axis system based on the original
            ' Set newAxisSystem = part.HybridShapes.AddNewAxisSystem(point)
            Set newAxisSystem = Part.AxisSystems.Add()
            newAxisSystem.Type = catAxisSystemStandard
            ' Set properties of the new axis system if needed
            newAxisSystem.Name = "AxisSystem_at_" & oPoint.Name
            ' Update the new axis system position (optional adjustments)
            newAxisSystem.OriginPoint = oPoint
            newAxisSystem.XAxisType = 1
            newAxisSystem.ZAxisType = 1
'            newAxisSystem.PutXAxis (vXValues)
'            newAxisSystem.PutZAxis (vZValues)
            newAxisSystem.XAxisDirection = vXValues
            newAxisSystem.ZAxisDirection = vZValues
            ' Add the new axis system to the part
        End If
    Next
    ' Update the part
    Part.update
    MsgBox "Axis systems copied to all points in the geometrical set."
End Sub
As can be seen, I've used both the GetXAxis/PutXAxis methods and the XDirection property, and CATIA chokes on both. The original code came from ChatGPT, which initially did not try to align the axes, but then when that was pointed out, it started making up properties/methods that aren't documented in the VB help. I'm at my wits end. Please let me know what I'm doing wrong. Thanks.
You should valuate XDirection (and other similar properties) property with HybridShapeDirection object created from original direction using it's component values.
But axis systems aren't a part of the HybridShape class. Not sure how that works.
Code:
    axissyst.GetOrigin originCoord
    Set originpoint = hybridShapeFactory1.AddNewPointCoord(originCoord(0), originCoord(1), originCoord(2))
    axissyst.GetXAxis axiscoord
    Set hybridShapeD1 = hybridShapeFactory1.AddNewDirectionByCoord(axiscoord(0), axiscoord(1), axiscoord(2))
    axissyst.GetYAxis axiscoord
    Set hybridShapeD2 = hybridShapeFactory1.AddNewDirectionByCoord(axiscoord(0), axiscoord(1), axiscoord(2))
    axissyst.GetZAxis axiscoord
    Set hybridShapeD3 = hybridShapeFactory1.AddNewDirectionByCoord(axiscoord(0), axiscoord(1), axiscoord(2))
regards,
LWolf
