CATScript Drawing SectionView
dddn
35
IT
Hi all, I wanted to ask for help to you users about a CATScript. I wrote a macro in which by entering the position vectors of the active view, I get the section view; Is there the possibility to refer to a plane created on the 3D model rather than referring to position vectors? For example: on the 3d model there is a plan called "Plan A", I would like this plan to be exploited to carry out the section.Thanks to all
Sorry but i don’t understand. Do you have possibility to write your solution?
Actualy i used a point of active2d view to generate a section view, but i want use a plane present on a cad 3d model
Thanks to all
