Gardenfence
- Jul 29, 2024
- 7
I am using Hypermesh. I am defining an ASET nodes for a model reduction, however, the nodes I am using are dependent nodes for an RBE3 element, so they cannot be used as my ASET.
I have defined coincident nodes at the same points as the nodes I want to define as my ASET and I want to use a CBUSH element to connect them, however, I cannot seem to get the CBUSH element to work. Here is a picture of my problem:
Every time I select the nodes and click apply, I get errors such as, "no receiving nodes found within tolerance" or "no springs created!" ect.
Does anybody know the process I am supposed to follow to fix this or get the CBUSH to work?
