CEN/TR 14549
Frazer1983
1
I'm doing some research here in the UK on ASME 31.3.
It is noted in Appendix N that i require to refer to CEN/TR 14549.
Does anyone have a copy of this so i can refer to what it actually means?
Thanks in advance
I have a copy (which I cant share for obvious reasons). In general it shows where B31.3 complies with PED requirements, and vice versa. It's more a sort of checklist you can use when you design piping under B31.3 which needs compliance with the PED 2014/68/EU. With that in mind, the purchase of the document (less than 100 euro I think) is worth the investment.
On a side note: CEN/TR 14549 used to be aligned with PED 97/23/EC. Is this has now become 2014/68/EU, you need to check if the CEN/TR 14549 has been updated accordingly.
