Tetragrammaton
Aerospace
- Nov 27, 2002
- 85
Hi All,
I'm using NX 12.0.2.9 and have a supplier model that was previously imported.
It comprises of a mixture of solid bodies and (unsewn) surfaces.
Trying to measure it various ways to identify the CoG does not appear to work on a component comprised of mixed bodies.
I don't need the mass, that is given by the supplier but I need the CoG for Stress analysis.
Is it possible to get this as I've never tried it on a component with mixed geometry with unswen surfaces?
I've tried various attempts using Object, Object Set with and without object filters without success.
Using Component with Object / Object Set, the Component highlights but not results dialog is displayed.
Understandably the only time I get a result is if I let it select the solid bodies the results dialog displays the CoG for the selected Object Set, though incomplete.
It seem to be clear that using a mixture of object types especially unsewn bodies will not allow a CoG to be defined.
Have others had any experience with this and what approach has yielded a result?
I will experiment with attempting to sew the surfaces but typically that is not always work so smoothly.
I will also attempt to request a solid body from the supplier but do not know if this is possible.
Any suggestion and insight would be appreciated.
Thanks in advance.
Best Regards
Tetragrammaton
Thanks in advance.
Best Regards
Tetragrammaton
