Cetop subplates
JMLH
Industrial
FI
What is your opinion on cetop subplates and their flow values? I haven't found a single subplate manufacturer that specifies a flow rate for their subplates.
Is it Ok to think that any kind of cetop 3 subplate is able to flow 60 l/min (or the same that the actual valves on top of it), regardless of the port size on it?
Even with 1/4" port threads? Oil line gets narrow right after the thread anyway. What do you think.
Of course the pressure loss gets higher with smaller lines, but does it make any significant difference with short distance?
