CFO License WallThicknessAnalysis 1
dddn
IT
Hello everyone,
would anyone be able to help me on how I can launch a "WallThicknessAnalysis" analysis, which is present on CFO license?
What I need is to launch the analysis select the body and run.
Thank you all!
To launch the analysis, you need to have the CFO active. In Tools-Options, General tab, look for the Shareable Products tab, scroll down to CFO and enable the tick box.
regards,
LWolf
Thank LWolf, but I need a help for launch this tool with a code write on CATScript.
Can you help me?
I don't believe that is possible. It is possible to CHECK whether the license is on (and give user a message that he/she needs to engage the CFO)
regards,
LWolf
Hello, i cant try it by myself because of no access to CFO licensing but if it won't work just tell me i will work on it.
Code:
Language= "VBScript"
Sub CATMain()
Dim oDoc1
Set oDoc1 = CATIA.ActiveDocument
Dim oPart1
Set oPart1 = oDoc1.Part
Dim oSel
Set oSel = oDoc1.Selection
Dim InputObjectType(0)
InputObjectType(0) = "Part"
oSel.Clear
status= oSel.SelectElement2(InputObjectType, "Choose body to measure", False)
CATIA.StartCommand "Wall Thickness Analysis"
End Sub
M
Hi LWolf
The objective is precisely to write the macro in the CFO environment; the problem is that I can not automatically launch the tool.
MKEdits, unfortunately your script ends with part selection.
He will definitely miss some steps.
Okay, try changing the line where i defined "InputObjectType(0)" from "Part" to "Body". Do you want to set specific tolerance and other options or just open tool window?
Sub CATMain()
Dim oDoc1
Dim oPart1
Dim oSel
InputObjectType(0) = "Body"
oSel.Clear
End Sub
M
Hi MKEdits,
ok the code is correct!! thank you so much.
Now, how do I set the tolerance and set the value 10 in the "Color" window and confirm to generate the analysis result (with a code)?
Thank MKEdits
You can't do it with catscript. Only with VBA and WinAPI.
And most likely you'll have to write code yourself because chances are low that someone have already dealt with the window.
Hi Little Cthulhu,
For me it would be fine to write in VBA too but where can I find a guide on how to call the functions that allow you to generate the tool?
Do you know any specific guides for the "Wall thickness analysis"?
Thank
