dik
- Apr 13, 2001
- 26,025
Current construction consists of Prefinished metal siding, densglass sheathing, 'Z' clips and 2x8@16 CFS vertical studs.
Should the Z clips be secured directly to the steel studs with the densglass fitting between and the siding connected directly to the z clips, or
Should the densglass be secured to the steel studs with the z clips secured through the densglass to the steel studs. The densglass acting as a bit of a thermal break and the siding connected to the z clips?
Any suggestions?
Dik
Any suggestions?
Dik
