i have two sample from bottom hole which provide flashed liq and flash gas and reservoir fluid composition. Now the sample is flashed from reservoir conditions to std conditions to get these composition. I have CGR ration as 28.88 stb/mmscf and the gas flow reqd is 60 mmscfd. How i get the composition for the fluid at plant battery limit from hysys?
do i take reservoir fluid and flash it from reservoir condition to std. conditions to get gas and liq and then recombine 60 mmscfd and 28.8 x 60 = 1728 bpd of liq? do i water saturate the gas before recombining?
