CGR to CATPart converter 1
VojtaR
Automotive
CZ
Hello everyone,
would anyone be able to modify this macro so it translates all CGRs in folder to CATParts?
Following macro is doing file by file, with manual selection of each file...
Code:
Sub CATMain()
   Dim sInputFile As String
   sInputFile = CATIA.FileSelectionBox("Choose cgr file...", "*.cgr", CatFileSelectionModeOpen)
   Dim sInputFileName As String
   sInputFileName = Left(sInputFile, InStrRev(sInputFile, ".") - 1)
   Dim sInputFileNameV4 As String
   If Len(sInputFileName) > 72 Then
       sInputFileNameV4 = Left(sInputFileName, 72) & ".model"
   Else
       sInputFileNameV4 = sInputFileName & ".model"
   End If
   Dim oDoc As document
   Set oDoc = CATIA.documents.Read(sInputFile)
   oDoc.ExportData sInputFileNameV4, "model"
   oDoc.Close
   Set oDoc = CATIA.documents.Open(sInputFileNameV4)
   Dim docSel As selection
   Set docSel = oDoc.selection
   If CATIA.SystemConfiguration.Release < "16" Then
       docSel.Search "Name=CAT_1000_1"
   Else
       docSel.Search "V4Model.MASTER"
   End If
   docSel.Copy
   Dim iPartNumber As String
   iPartNumber = Mid(sInputFileName, InStrRev(sInputFileName,  CATIA.FileSystem.FileSeparator) + 1)
   Set oDoc = CATIA.documents.Add("Part")
   Dim iProduct As Product
   Set iProduct = oDoc.Product
   iProduct.PartNumber = iPartNumber
   docSel.Add iProduct
   docSel.Paste
   iProduct.Update
   oDoc.SaveAs sInputFileName & ".CATPart"
   oDoc.Close
   Set oDoc = CATIA.documents.Item(CATIA.documents.Count)
   oDoc.Close
   Set oDoc = CATIA.documents.Open(sInputFileName & ".CATPart")
End Sub
Thank you.
I'm sure there are peoples here who can modify the script but it would be interesting for you to modify it yourself. You can start searching the forum for keyword batch. There are several examples here and also in CATIA Portable Script Center (and in DS documentation).
Fernando
