Alistair_Heaton
C24 45 mm rafter compressed between two angle plates.
Does any one have any links to any factors you can apply.
Its to see what the bearing strength is with a 52 deg pitched rafter with an M10 bolt through it connecting the plates in double shear.
Be gentle I haven't practised for 20 years as an engineer and when I did it was never with wood. And its not for a commercial job.
