Change Journal to add Density
Kenja824
Automotive
Nov 5, 2014
950
NX1872
Currently, GM gives us a material list that is automatically read when we go to tools > Materials > Assign Materials. Then to assign simple Steel 1020 to a solid body, they need to search through a really long list of materials and it gets annoying to them when they have to do this often. So I figured I would try and create a button that lets them select a solid body or multiple solid bodies and add the correct density to it so it will have the correct weight.
I have a journal that allows the user to select a solid body and it will add particular attributes to it. I was hoping to record myself selecting a solid body and changing the solid density to a specific number and add this to that code in place of the attributes. It isnt going so well. lol
In the below code, I have the code I recorded placed between two long rows of asterisks to make it easy to see what I added. I have tried commenting out things and changing words from (Body1) to (theBodies) and everything. I am starting to think I am not even on the right track of how this works.
Currently it gives me a Null Tag on the following bit of code....
nXObject2 = solidDensity1.Commit()
Code:
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Dim theSession As Session = Session.GetSession()
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim theUI As UI = UI.GetUI()
    Dim lw As ListingWindow = theSession.ListingWindow
    Sub Main()
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "body attributes")
        lw.Open()
        Dim selobj As NXObject
        Dim type As Integer
        Dim subtype As Integer
        Dim theBodies As New List(Of Body)
        Dim numsel As Integer = theUI.SelectionManager.GetNumSelectedObjects()
        'process the preselected bodies
        If numsel > 0 Then
            For inx As Integer = 0 To numsel - 1
                selobj = theUI.SelectionManager.GetSelectedTaggedObject(inx)
                theUfSession.Obj.AskTypeAndSubtype(selobj.Tag, type, subtype)
                If type = UFConstants.UF_solid_type Then
                    theBodies.Add(selobj)
                End If
            Next
        Else
            'prompt to select bodies
            If SelectBodies("Select Bodies to add Material to", theBodies) = Selection.Response.Cancel Then
                Return
            End If
        End If
        For Each temp As Body In theBodies
            ' DeleteAllAttributes(temp)
            'AddBodyAttribute(temp, "TOOL_CLASS", "ALT STD")
            'AddBodyAttribute(temp, "STOCK_SIZE", "ANI201")
            'AddBodyAttribute(temp, "PURCH_OPTION", "P")
            'AddBodyAttribute(temp, "DB_PART_NAME", "NC BLANK")
            Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
            Dim workPart As NXOpen.Part = theSession.Parts.Work
            Dim displayPart As NXOpen.Part = theSession.Parts.Display
            '           Dim markId1 As NXOpen.Session.UndoMarkId = Nothing
            '           markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Start")
            Dim solidDensity1 As NXOpen.GeometricAnalysis.SolidDensity = Nothing
            solidDensity1 = workPart.AnalysisManager.CreateSolidDensityObject()
            '          solidDensity1.Density = 1.0
            solidDensity1.Units = NXOpen.GeometricAnalysis.SolidDensity.UnitsType.PoundsPerCubicInches
            theSession.SetUndoMarkName(markId1, "Assign Solid Density Dialog")
            '            Dim theUI As UI = UI.GetUI()
            Dim added1 As Boolean = Nothing
            added1 = solidDensity1.Solids.Add(CType(theUI.SelectionManager.GetSelectedObject(0), NXOpen.Body))
            solidDensity1.Density = 15.0
            Dim markId2 As NXOpen.Session.UndoMarkId = Nothing
            markId2 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "Assign Solid Density")
            theSession.DeleteUndoMark(markId2, Nothing)
            Dim markId3 As NXOpen.Session.UndoMarkId = Nothing
            markId3 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "Assign Solid Density")
            Dim nXObject2 As NXOpen.NXObject = Nothing
            theSession.DeleteUndoMark(markId3, Nothing)
            theSession.SetUndoMarkName(markId1, "Assign Solid Density")
            solidDensity1.Destroy()
        Next
        lw.Close()
    End Sub
    Function SelectBodies(ByVal prompt As String, ByRef selBod As List(Of Body)) As Selection.Response
        Dim title As String = "Select bodies"
        Dim includeFeatures As Boolean = False
        Dim keepHighlighted As Boolean = False
        Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
        Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
        Dim selectionMask_array(0) As Selection.MaskTriple
        Dim selObj() As TaggedObject
        With selectionMask_array(0)
            .Type = UFConstants.UF_solid_type
            .Subtype = 0
            .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_BODY
        End With
        Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObjects(prompt, title, scope, selAction, includeFeatures, keepHighlighted, selectionMask_array, selObj)
        If resp = Selection.Response.Ok Then
            For Each temp As TaggedObject In selObj
                selBod.Add(temp)
            Next
            Return Selection.Response.Ok
        Else
            Return Selection.Response.Cancel
        End If
    End Function
    'Sub AddBodyAttribute(ByVal theBody As Body, ByVal attTitle As String, ByVal attValue As String)
    '    Dim markId4 As Session.UndoMarkId
    '    markId4 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "add body attribute")
    '    Dim attributePropertiesBuilder1 As AttributePropertiesBuilder
    '    attributePropertiesBuilder1 = theSession.AttributeManager.CreateAttributePropertiesBuilder(theSession.Parts.Work, {theBody}, AttributePropertiesBuilder.OperationType.None)
    '    attributePropertiesBuilder1.IsArray = False
    '    attributePropertiesBuilder1.DataType = AttributePropertiesBaseBuilder.DataTypeOptions.String
    '    attributePropertiesBuilder1.Title = attTitle
    '    attributePropertiesBuilder1.StringValue = attValue
    '    Dim nXObject1 As NXObject
    '    nXObject1 = attributePropertiesBuilder1.Commit()
    '    Dim id1 As Session.UndoMarkId
    '    id1 = theSession.GetNewestUndoMark(Session.MarkVisibility.Visible)
    '    Dim nErrs1 As Integer
    '    nErrs1 = theSession.UpdateManager.DoUpdate(id1)
    '    attributePropertiesBuilder1.Destroy()
    'End Sub
    'Sub DeleteAllAttributes(ByVal theObject As NXObject)
    '    Dim attributeInfo() As NXObject.AttributeInformation = theObject.GetUserAttributes
    '    For Each temp As NXObject.AttributeInformation In attributeInfo
    '        theObject.DeleteUserAttributes(temp.Type, Update.Option.Now)
    '    Next
    'End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
Some direction would help. Explanations would be appreciated, but keep them in laymans terms if possible. lol
Ken
My brain is like a sponge. A sopping wet sponge. When I use it, I seem to lose more than I soak in.
Hi
I have modified your code slightly....
Now it works....
Seems like you didn't add the correct Solid, to the DensityObject...
You need to deal with each cycled Body - in your case the variable is "temp"...
your code wrong here: added1 = [highlight #EF2929]solidDensity1.Solids.Add(CType(theUI.SelectionManager.GetSelectedObject(0), NXOpen.Body))[/highlight]
my changes: [highlight #8AE234]solidDensity1.Solids.Add(temp)[/highlight]
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        lw.Open()
        Dim type As Integer
        If numsel > 0 Then
                End If
            Next
        Else
                Return
            End If
        End If
  lw.writeline(theBodies.Count)
            '*********************************      Modified section by Lklo             *********************************
            'prepare a CreateSolidDensityObject
            solidDensity1.Units = NXOpen.GeometricAnalysis.SolidDensity.UnitsType.KilogramsPerCubicMeters
        Next
        lw.Close()
    End Sub
            .Subtype = 0
        End With
                selBod.Add(temp)
            Next
        Else
        End If
    End Function
    'End Sub
    '    Next
    'End Sub
    End Function
End Module
Please keep in mind, that your code only works proper when you try assign density to a solid Body, that is NOT assigned a physical Material....
If you will continue in this direction, consider optimize code, so it will remove material id exists.....
When this being said, try consider develop a NXOpen utility, that can deal with the Materials from the NX material library...
I have developed a Tool (6000+ lines of journal) that can handle this action...
some Features:
* assign materials to solid in MODEL refset
* support multiple parts in same action...
* assign part list attributes in same operation..
* all information is based on a spreadsheet for each product....a Tab in the dialog for each...
see attached screen shots for information...
lklo
 https://files.engineering.com/getfile.aspx?folder=7669eb4b-051d-41a8-99b4-164edb5abd4b&file=physical_material_manager_3.zip
