hello everyone,
I created a macro in which I guide the user till the intersection of two elements. But I cannot seem to change the radius of circle using Userform.
The code I created:
Sub CATMain()
Dim oDoc As Object
Set oDoc = CATIA.ActiveDocument
Dim oPart As Part
Set oPart = oDoc.Part
Dim hybridShapeFactory1 As Object
Set hybridShapeFactory1 = oPart.HybridShapeFactory
Dim oSec As Object
Set oSec = oDoc.Selection
oSec.Clear
Dim Msg As String
Msg = "作成したポイントを選択してください。"
Dim InputObjectType()
ReDim InputObjectType(0)
InputObjectType(0) = "Plane"
Dim Status As String
Dim hybridShapeCurveExplicit1 As Object
If Status <> "Cancel" Then
Status = oSec.SelectElement2(InputObjectType, _
"方向を選択してください。", False)
End If
Dim reference As reference
Set reference = oSec.Item(1).reference
Dim InputType()
ReDim InputType(0)
InputType(0) = "Point"
Dim Status1 As String
If Status1 <> "Cancel" Then
Status1 = oSec.SelectElement2(InputType, _
"ポイントを選択してください。", False)
End If
Dim reference1 As reference
Set reference1 = oSec.Item(1).reference
Dim hybridBodies1
Set hybridBodies1 = oPart.HybridBodies
Dim hybridBody1
Set hybridBody1 = hybridBodies1.Item(1)
Dim hybridShapePlaneNormal1
Set hybridShapePlaneNormal1 = hybridShapeFactory1.AddNewPlaneOffsetPt(reference, reference1)
hybridBody1.AppendHybridShape hybridShapePlaneNormal1
oPart.InWorkObject = hybridShapePlaneNormal1
oPart.Update
Dim Status2 As String
If Status2 <> "Cancel" Then
Status2 = oSec.SelectElement2(InputObjectType, _
End If
Dim reference2 As reference
Set reference2 = oSec.Item(1).reference
Dim hybridShapeCircleCtrRad
Set hybridShapeCircleCtrRad = hybridShapeFactory1.AddNewCircleCtrRad(reference1, reference2, False, 150)
hybridShapeCircleCtrRad.SetLimitation 1
hybridBody1.AppendHybridShape hybridShapeCircleCtrRad
oPart.InWorkObject = hybridShapeCircleCtrRad
oPart.Update
Dim hybridShapeFill1
Set hybridShapeFill1 = hybridShapeFactory1.AddNewFill()
Dim reference3
Set reference3 = oPart.CreateReferenceFromObject(hybridShapeCircleCtrRad)
hybridShapeFill1.AddBound reference3
hybridShapeFill1.Continuity = 1
hybridShapeFill1.Detection = 2
hybridShapeFill1.AdvancedTolerantMode = 3
hybridShapeFill1.MaximumDeviationValue = 0.005
hybridBody1.AppendHybridShape hybridShapeFill1
oPart.InWorkObject = hybridShapeFill1
oPart.Update
Dim InputObject()
ReDim InputObject(0)
InputObject(0) = "AnyObject"
Dim Status3 As String
If Status3 <> "Cancel" Then
Status3 = oSec.SelectElement2(InputObject, _
"一つ目のエレメントを選択してください。", False)
End If
Dim reference4 As reference
Set reference4 = oSec.Item(1).reference
Dim Status4 As String
If Status4 <> "Cancel" Then
Status4 = oSec.SelectElement2(InputObject, _
"二つ目のエレメントを選択してください。", False)
End If
Dim reference5 As reference
Set reference5 = oSec.Item(1).reference
Dim hybridShapeIntersection1
Set hybridShapeIntersection1 = hybridShapeFactory1.AddNewIntersection(reference4, reference5)
hybridShapeIntersection1.PointType = 0
hybridBody1.AppendHybridShape hybridShapeIntersection1
oPart.InWorkObject = hybridShapeIntersection1
oPart.Update
End Sub
And this is the userform i created:
I want the text box to enter the radius value of circle and on pressing the button OK the circle i created in the above code changes its radius.I tried the code given below but it does not seem to work.
Private Sub OKButton_Click()
Dim HybridShapeCircleRadius As Length
If TextBox1.Value > 0 Then
Change.Value = HybridShapeCircle.Radius
oPart.Update
End If
End Sub
any help will be appreciated. Thankyou.
The code I created:
Sub CATMain()
Dim oDoc As Object
Dim oPart As Part
Dim oSec As Object
oSec.Clear
Dim Msg As String
End If
Dim InputType()
ReDim InputType(0)
End If
Dim hybridBodies1
Dim hybridBody1
oPart.Update
End If
oPart.Update
Dim reference3
oPart.Update
Dim InputObject()
End If
End If
oPart.Update
End Sub
oPart.Update
End If
End Sub
