  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
Changing heat flux rapidly causes the simulation to diverge
Alexander Koss
Automotive
Apr 8, 2020
24
0
0
DE
I am currently working on a Subroutine, which would dynamically change the heat flux inside the material depending on the temperature. If I change the heat flux within 1 step from 5 to 0 (example values), it would crash. It works if I change it from 5 to 3 though. I'm pretty new to subroutines and working with those, so any help would be great!
Does it happen only when you turn the heat flux off ? What is the error message that you get when the analysis crashes ? Are there any additional warnings in output files generated by Abaqus ?
It seems to be caused by a too rapid change in Heat Flux
The message is "HEAT FLUX EQUILIBRIUM NOT ACHIEVED WITHIN TOLERANCE."
The issue is, I would have to change it to zero at some point throughout the simulation (to be exact, as soon as all the heat will be exhausted)
Is there a way to change the heat flux to zero, without having the following issue?
