Designer_82
Working on a mixed-use building (retail/residential) currently supplied by single phase service.
The single phase needs to be upgraded to 3 phase to handle some larger loads going in one of the retail spaces.
There's an existing 1 phase meter center. I'm unsure if there would be any problems with the new supply voltage/compatibility to this meter center since building will now get 3 phase.
Maybe the heating units in the apts. will output less heat?
Maybe issues with any other existing 240V loads changing to 208V?
Appreciate your feedback.
