Check NX is IDLE or not using NXOpen
Maddy02
114
Hi
Is there anyway to find whether NX is idle or not.
Thanks in advance.
Maddy
Does the black moon howl? You can use UF_is_initialized() to check if the NXOpen is in use, and NXOpen::UI::GetUI()->AskLockStatus() to see if the NX UI is locked (because it's busy doing something)
