I have problem with check which components are suppressed in active arrangement in assembly.
I try with this, but without positive results:
Maybe someone could find fault in my code or show me right way to success.
Best regards
MANok
NX2027
TC14
Code:
Imports NXOpen.UF
Imports NXOpen.Assemblies
Imports NXOpen.Assemblies.Component
Module Arrangement_tester
Dim arrtheSession As Session = Session.GetSession()
Dim workPart As Part = arrtheSession.Parts.Work
Dim displayPart As Part = arrtheSession.Parts.Display
Dim startWorkPart As Part = arrtheSession.Parts.Work
Dim startDispPart As Part = arrtheSession.Parts.Display
Public ufs As UFSession = UFSession.GetUFSession()
Public lw As ListingWindow = arrtheSession.ListingWindow
Sub Main()
lw.Open()
Try
Dim c As ComponentAssembly = displayPart.ComponentAssembly
Dim activeArr As Arrangement
activeArr = c.ActiveArrangement
For Each child As Component In c.RootComponent.GetChildren()
Dim IsSuppresed As Boolean
c.GetSuppressedState(child, activeArr, IsSuppresed)
If Not IsSuppresed Then
lw.WriteLine(child.DisplayName & " is suppresed")
End If
Next
Catch e As Exception
arrtheSession.ListingWindow.WriteLine("Failed: " & e.ToString)
End Try
lw.Close()
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
Return Session.LibraryUnloadOption.Immediately
End Function
End Module
Best regards
MANok
NX2027
TC14
