ccc123
- May 17, 2006
- 38
I have asystem with two pumping stations.The first station is pumping to the second with about 50bar. Due to power failure the expected surge pressure on the first pumping station is about 70 bar.The system is protected against surge by using surge tanks, at the discharge line of each booster pump in the station their is one check valve,But their are no check valve installed at the main pipeline between both stations, My question : is it recommended to install check valves at the line between the two stations to prevent back pressure or it's enough to depend on the surge tanks ? where it is recommended for installation ?
If the CV will be installed at theinlet line of the surge tank this will prevent the surge tank from working, so no need for surge tank ??
