Engingeeer
Hello, our customer has a drawing similar to this one. How would you check these dimensions (+/-2 mm) if the surfaces of the body are unusable (bent sides during welding). You can only orient yourself to bases A and B. Large surfaces on the sides cannot be used.[URL unfurl="true"]https://res.cloudinary.com/engineering-com/image/upload/v1715869021/tips/Body_Check_qpsbdl.pdf[/url]
thanks for your help
